I purchased a MOTOROLA MT7711. Three years old and never a problem.
Interesting, I have the same one, running flawlessly for years with incredible range but I guess any electronic can fail.It has been a messy few days.
Spectrum internet went out.
Since we stream, that also meant no TV.
Mrs. Tdbo unhappy. Guess how that goes.
Three techs told me that it was their issue, and we needed a tech out to the house.
We finally got internet and TV because I took a trial out on a T Mobile pod.
Back to the story. Finally got a tech that knew what he was doing, adjusted signal, and found out that my Router crapped.
Motorola AC2600 lasted 13 months. It is still under warranty, but I want to get this rectified PDQ because nothing is working right.
I'll warranty the Motorola but I need a router like yesterday.
Looking at Amazon because we have prime.
Need recommendations for Routers. Budget: $150 or less.
Thanks in advance.
I'm not surprised. When we moved into our current place 3 years ago, 4 Comcast subcontractors couldn't get wifi correct. The 5th guy mostly did but I still ended up paying a guy that specializes in setting up home theaters, internet , outside TVs, media rooms etc... a$ 1000 to install a Moca connection and set up wifi optimally in the house. Worth every penny.Interesting, I have the same one, running flawlessly for years with incredible range but I guess any electronic can fail.
My bigger question would be why it took 4 techs to figure out your router was no good? Something does not sound right, that is one of the first things they check for. Something isnt right with what they did or more to the story? I am not questioning you.
This is basic stuff, how can three techs not check to see if your modem was working in a correct way? It's step one of trouble shooting and in each case when they did not have a signal at the modem they knew it was their problem. Then a 4th guy comes and says it was your router? Scary stuff!!
+1A bit more than your budget, but I'd recommend this:
https://www.amazon.com/Ubiquiti-Net...d=1689536259&sprefix=dreamrout,aps,117&sr=8-2
I won't buy any WiFi device that can't be run via Power Over Ethernet
That's not exactly right. The extension mesh link requires a decent signal from the unit that is connected to the Internet to work. It should be placed somewhere midway between the main unit and the farthest extent of the house. Users needing extended coverage work on the far side of it. If you put the extension unit in the heart of a dead spot, it's going to be rather dead as well.other two where the signal is the weakest in the house.
Take his advice, have Spectrum give you the modem and get your own router.I am quite clueless on all of this stuff. I am old and old school.
We bought our current house eight years ago. At that time, Spectrum was already set up in the house from the previous owners. I purchased a combo modem/router and have used it since. Long story, but I have been meaning to update. Also a long story, but we had a Spectrum tech out to the house a few days ago, so I got some suggestions from him. He seemed very nice and knowledgeable, an older gentleman. He said he is not supposed to suggest such things to me, but...
He recommended that I get the "free" modem from Spectrum and buy a TP link mesh system that would have three routers. He said put one by the modem and the other two where the signal is the weakest in the house. I have a two-story house; each level is approximately 900 square feet or so.
He said we currently have 300 Mbps but he only measured 127 coming out of my current modem/router combo unit, Netgear brand.
Thoughts? Suggestions?
Ordered. Thank you.Take his advice, have Spectrum give you the modem and get your own router.
TpLink is a good reliable brand.
https://www.amazon.com/Mesh-Wifi-6-Router-System/dp/B085Z35GY6/ref=mp_s_a_1_4
Very cool, update us if you can once you get it hooked up. It certainly seems like great value and TpLink is known for that.Ordered. Thank you.
Speedtest.net. If you want real world results like if you’re using a laptop or whatever from the couch do it like that. If you want to see if you’re getting the speed you pay for, plug a computer right into the router or some routers like my Asus have a built in Speedtest feature.What is the best method for a person to perform their own "speed test" at home?
