I wish you said that initially, I had the SDS pulled up. I'll go get them again. It's all on the Shell server.I was looking more at the viscosity numbers they posted.
What oil are you currently running? Are you seeing low oil pressure or just imagining its inadequate? The KV100 viscosity is not really the indicator of "better", as @kschachn mentioned, the HTHS is what you might look to for HD high stress applications, this is assuming the DP/AW additive package is same/similar.
#OLEJOE you are correct this is incorrect data, solid SAE 40 grade KV100 and a15W CCS test temp.
It's listed on the US server.AFAIK, there is no T6 10W-30 - there is T6 15W-40; and T5 10W-30 that is a synthetic blend.
