Z ZZman Joined Mar 17, 2008 Messages 8,427 Location Michigan Jun 6, 2017 #1 http://www.autoblog.com/2017/06/05/robinone-car-oil-purification-skip-changes/
R RichardS Joined Jan 14, 2017 Messages 660 Location Melbourne, Florida Jun 6, 2017 #2 So since this is round 3, what benefit do you really achieve? It's a detachable bypass. Unless it removed TAN's, could it really extend the service life of the oil in a standard gas PCMO?
C CharlieBauer Joined Mar 29, 2016 Messages 1,512 Location CA Jun 6, 2017 #4 Looks like they're using a MicFil (German company) 0.5 micron filter and pumping at just under 60psi. You can buy the filter itself for $28. MicFil sell it as part of filtration systems for industrial use and make similar claims of what it can do.
C CharlieBauer Joined Mar 29, 2016 Messages 1,512 Location CA Jun 6, 2017 #5 Here's a datasheet on the filter: http://www.micfil.net/hp/LinkClick.aspx?fileticket=vfGNioJJmEg%3d&tabid=127&portalid=0&mid=594&language=en-US
C CharlieBauer Joined Mar 29, 2016 Messages 1,512 Location CA Jun 6, 2017 #6 Originally Posted By: CharlieBauer Here's a datasheet on the filter: http://www.micfil.net/hp/Portals/0/Docum..._Data_Sheet.pdf I just updated the link as it wasn't always working smoothly. Here are some interesting specs for the smallest size of the smallest ultrafine 0.5 micron filter, which I'm guessing they're using in the RobinOne. - Specified for engine oil tank size of 50 litres. - 500 to 600 hours filter life which would be when bypass filtering 50 litres So you can see why RobinOne say the filter is good for 20 purifications in a car engine. - The published efficiency in the data sheet at 2 microns is 93% for gearbox oil, 95% for diesel fuel, 97% for hydraulic oil.
