Flashpoint is very high especially for closed cup testing..
Quote:
The viscosity dropped somewhat. Perhaps this is normal?
From UOA:
Visc40 38.5
Visc100 7.8
From RLI Spec for 0W-20:
Visc40 44
Visc100 8.8
Quote:
While it is definately an improvement I can not see where the previous UOA was that bad. Sure fuel dilloutin was up a bit but did you ever try RTS to see how that did or M1 0W40??? I only ask becuase RLI is some expensive stuff. the only real significant difference in my mind is the level of fuel dillution.
Quote:
Bruce, Blackstone uses a open cup measurement for flashpoint, whereas Dyson's contract lab uses closed cup. Blackstone has shown consistently to miss fuel dilution. They compute dilution from flashpoint and seem to get flash wrong. The Dyson numbers for flashpoint and fuel dilution can be cross checked. Dilution is measured with FTIR, whereas flashpoint is measured with closed cup testing. The correlation between the two is extraordinarily good. The only valid comparison you can make for this UOA is against the last UOA done at Dyson Analysis, which is posted somewhere in in this thread.
Quote:
Is it possible to make a comparison between the Biosyn and the Mobil 1? To my simple way of looking at the numbers, the Mobil 1 appeared to do just as well as the Biosyn. Given that Mobil 1 noticeably cheaper, is Mobil 1 a better choice. I ask because I have been using Mobil 1 and am planning to switch to Biosyn for comparison.
Quote:
It is my understanding the RLI is using the results of many UOA's in various engines to fine tune and improve their formulations. This oil, rather than being fossilized like most oils, is actually evolving. That bodes well for us consumers.
