My Impala with the 3.4L has a slight oil consumption problem that I'm trying to cure. It's not much, maybe only a half quart every 1k miles, but in a 4 quart sump, any unsolved consumption has my attention. I have switched to T6 5w30, hoping that a little thicker oil might help. So far, it seems to have helped a bit, but I wanted to go ahead and replace the PCV valve as well. However, the PCV valve has this riveted bracket on there that I've never seen before. I'm not sure how to remove it and I've heard conflicting reports as to how far the rivets go. Some people say it goes all the way through the VC, others say it doesn't. Any ideas on how to get this out, or would it just be best to remove the VC?
