You're supposed to check it?
You can't do that on my Durango or Charger, both equipped with the Pentastar. Oil will climb the dipstick overnight about 2", so it looks like the engine is way overfilled. You have to pull the dipstick, clean it, then take a measurement. If you quickly pull the dipstick immediately after it seats or seat it and wait 10 seconds, you'll get a different reading every time.My Mazda 3 has a straight dipstick right thru the valve cover, head and block. I can pull it after sitting overnight and peek at the oil level without even fully removing it from the hole. Always FULL as it has been for the 10 years I’ve owned this thing.
I put my money were my mouth is and did a test.No way. I think some of us on here are starting to lose it.Waaaaay too much time on the oil forum. (My wife always makes fun of me “you reading about oil again?!?!”)
Although I’m always servicing HOT engines at the shop, I do occasionally pull in something that was dropped off the night before and is COLD. I’ve never reinserted a dipstick and purposely waited for some magic to happen for any longer than half a second before YANKING it outta there to read it.
On a hot engine with oil still draining down, some dipsticks are made so idiotic that if you want even a few seconds, it will be completely covered with draining oil and you won’t be able to read the level and have to re-wipe and do a super quick “in & out” to get a reading.
Waiting even 5 seconds on a completely cold engine with all the oil drained into the pan is CRAZY to me.![]()
I agree, I'm just trying to be a consistent as possible.Wilson, a dipstick is not the most accurate device on the vehicle.
if it is between Add and Full is all I ever looked for.
if you dont park the vehicle in exactly the same spot you can get some inconsistency, just because floors or the ground are very rarely perfectly level.
I have a set process to check the oil in my 2012 Ford Transit Connect. No matter how long or where it sets for some reason the dipstick when first pulled will have very little oil on it. It’s like a vacuum has pulled the oil out of the dipstick tube. Once pulled I reinsert it and wait a few seconds and then it will show the proper oil level. It’s done this since day one and the first time I checked the oil it freaked me out. Now it’s got over 210k miles on it. Still doesn’t use any oil.I agree, I'm just trying to be a consistent as possible.
How difficult is it to take out? If it doesn't take more than 30 minutes, then it would be worth the time and aggravation.The bulkhead at the back of the engine compartment that separates the cowl area from the intake manifold comes out and makes doing anything on the rear of the engine on a Durango or Grand Cherokee of this vintage easier.
Mine had two. Motor City Mechanic did mention that some have three.@wwillson , was there two bolts or three holding the valve on?
Indeed he did, was curious about your's, a job well done!Mine had two. Motor City Mechanic did mention that some have three.
