Originally Posted by Exhaustgases
There are so many things that could have been done to that vehicle and others that are setting speed records, and the rule books need to be changed to allow devices that will help save lives in vehicles like that.
That vehicle was a complete disaster waiting to happen. It finally did. It looked like it was designed on the back of a cocktail napkin during a 2 for 1 happy hour. That should have stayed that way until someone foolishly managed to get enough money thrown at it, to get the thing built.
A 50's surplus fighter with the wings cut off, and an I-Beam mounted to the back with a couple of wheels bolted on. All built without a roll cage, or most any other driver protection.
The only thing that was "amazing" about it, was it took so long before it finally killed someone. If you look at most every land speed record car to date built by Cobb, Arfons, Breedlove, or the Thrust SSC Team, all were purpose designed, engineered, and built from the ground up as such. Not some chopped up, pieced together, cut rate abortion.
It's sad she had to be the one driving it when it all went south. These cars are dangerous enough when no engineering, construction, or safety expense is spared. Anything short of that is pointless suicide.
