Riding Mower Reviews
Originally Posted By: 330indy
Does anyone know of a device that allows one to easily sharpen lawnmower blades while they’re attached? Something you could swipe across the blade like a two sided stone or something abrasive? This tool would make it handy
If you are able to get under it and file it, you can take the blades off easier and just shapen them in a vise with a file, or angle grinder. Too much work to try sharpening them on the mower. I don't see how you can get a proper edge with the blade on the mower.
Not much room under there. So a drill or even an
air tool would be dangerous to use in that tight
quarter.
My 2¢
Can't be that hard to remove. I would want to make sure it's balanced when done too, can't do that on the mower.
A file.
Too big
Keep an extra set of sharpened blades and swap as needed.
Look at the deck. More casters and heavier gauge steel on the deck is the mower to buy. 9/10 times the deck is the first thing to give it up on a homeowner
grade mower.
That's what i do. Take them off, put on the sharp ones. On a rainy day, nothing to do, sharpen them in the garage.
