Restore and protect opinions
Is this due to more volatile solvents that can burn off at the high test temp?
It seems that they just use a "less than" for all their products, in regards to NOACK
I am a fan of Valvoline products, and bought some of the new R&P. On the next oil change I will use it and do tests, if I remember
Valvoline R & P
Cheap Premium Blue Restore?
A very different product than Premium Blue Restore (PBR)
Restore and Protect is designed to clean slowly over a series of four-(4) oil changes. The chemistry is reported to be significantly different than PBR; based on synthetic cleaners and additives being researched by Valvoline. Slower cleaning is said to protect the engine by not overloading the oil filter.
Would you like those numbers in Western Arabic Numerals, Hindu-Arabic or Gumbar Numerals?
The Hindu would be fine, since I can always call this guy from my old High School that is from India. I think he was born here or maybe he came to this country when he was a small child. If he can count from like 1 to 20 in Hindu or read the numbers, I am so set.
Is Premium Blue Restore still available??
A very different product the Premium Blue Restore (PBR)
Restore and Protect is designed to clean slowly over a series of four-(4) oil changes. The chemistry is reported to be significantly different than PBR; being based on synthetic cleaners and additives being researched by Valvoline. Slower cleaning is said to protect the engine by not overloading the oil filter.
Got it thank you.
Yes
Put R&P in 2019 Sonata 2.4 I just bought. It had 23K miles on it and recent oil change. I Immediately swapped in R&P.
2K miles later not a single drop of oil consumed. I don't have any history on the car prior other than servicing intervals, so prior consumption is unknown.
