Best to have the iridum electrode WITH a Platinum enhancement on the ground tab.
MANY vehicles use a "wasted spark" system that has a positive spark on 1 bank and a negative spark on the other bank.
What this means for spark plug life is that on one side of the motor, the electrode wears faster.....and on the other side of the motor, the ground tab actually wears faster.
Using a multi-pronged spark plug does NOT seem to help, at least not on FORD.
My '96 FORD Windstar specifies "double Platinum" spark plugs, which has platinum on the electrode AND on the ground tab.
The Factory original spark plugs, also rated for 100K miles had a platinum electrode and no platinum enhancement on the ground tab on 1 side of the motor.......and the spark plugs on the other side had the platinum enhancement on the ground tab.
However, these are not available in the aftermarket (it is confusing enough already), so that is why you need the double platinum.
Also note that not all Iridium are long life spark plugs.......Denso sells a "Power Plus" Iridium spark plug that has a 4mm electrode.......and they (Denso) rates them for ONLY 30K miles.
Their Long Life spark plug for the same application has a 7mm electrode and platinum enhancement on the ground tab and rates them "up to" 120K miles.
So, it pays to read up on what you are thinking of buying.
