I don't believe you're straining anything at least not with Coil on Plugs.
Maybe a standard single coil & distributor setup but not coil on plug. Coil on plug was specifically built for lower maintenance and improved performance.
I really like to see those expensive ignition components as well.
If less than $100 is to much for you than maybe so is owning a car.
