cheesepuffs
Originally Posted By: slacktide_bitog
If it's the your Accord V6 in your sig, then iridium is a MUST! Because you know that the transverse V6 is IMPOSSIBLE to work on since you have take apart half the engine to access the rear plugs, and you do NOT want to do it again!
Get the Denso iridium from AAP with a 30% off promo code which makes them $10.49 each. And if your local AAP doesn't have them, or if they don't even have a store nearby, you get free shipping, too
Bosch makes iridium California-spec spark plugs for your Accord, too. Rock Auto has them for about $5 each.
Also, get the valve cover gaskets. You might as well replace them while you have the engine apart. Get the Mahle brand from Rock Auto. And replace every gasket you have to remove when fighting your way to the back of the engine.
If you had the 4-cylinder, then no, you wouldn't need iridium, because even if you had any problems, they're easy to change out.
I know you're trying to help and I appreciate that, but I want anybody reading this to know that what you said about the rear plug access is 100% false. You can very easily reach the rear plugs and absolutely nothing except for the coils packs need to be removed.
