I've had really good luck rejuvenating old hardened hoses that are exposed to oil. PCV hoses and such. Gaskets and any other synthetic rubber parts that have been hardened over time from engine use. As long as they are not compromised with cracks.
I soak in lacquer thinner for a while until they become pliable then soak in Rislone for 24 hrs. You can see the thinner darken as it pulls out the carbon black. Time varies for a few minutes to hours so you have to keep testing pliability and over shoot a bit.
If you don't soak in oil afterwards the thinner just evaporates from the rubber and it is not near as pliable as new. Just doing this on a 23 year old mower PCV hose.
I use Rislone to soak it in. I don't know why. It's the same two quarts I've had for decades.
Would some other product be better for the oil soak?
