Originally Posted By: harry j
I use the spot free rinse at the local car wash to carefully wash down the engine, no drying required.
The keyword is "carefully." Personally, I'm too afraid of "hosing up" the electrical connections (pun intended).
If one uses Eagle One all wheel cleaner, would that not strip off the Rejex? So, if you use Rejex on your wheels, then a water rinse is the only recommended cleaning method to remove brake dust and road grime?
Bret, what about using a clay bar, then a pre-wax cleaner/conditioner, THEN using Rejex? Will it work?
And last, Rejex versus Insulator Wax for durability and shine? And the winner is..........?
