Water Wetter is simply a soap surfactant.
It has no corrosion inhibitor.
Engine Ice is simply a pre-mixed dionized water with propylene glycol solution...at about $34 a gal.
Actually, if you use ethylene or propylene glycol solutions, that should serve as a surface tension reducer in itself. Water wetter would be overkill.
