Hopefully I am not going to be burned at the stake for this first post. I'm a new owner of a 2006 Mazda3 2.3L and was shocked to see they recommend 5w20 oil for it. So I did some research on it, and found an excellent article at the link below. I believe it was posted here by one of the contributers.
Oil Fuel Mileage Paper
This certainly answered my questions about why it is recommended, so my next undertaking was to identify the best Xw20 oils based on HTHS viscosity. It seems to be the critical factor in getting the best fuel mileage and most HP out of the engine. Following is my list in order of best to worst, with a few 5w30's thrown in for comparison.
Manufacturer Type & Grade, HTHS, VI
Pennzoil Platinum 5w-20, 2.6*, 160
Castrol SYNTEC 5w20, 2.6*, ??
Mobil 1 0w-20, 2.61, 165
Mobil 1 5w-20, 2.62, 163
Motorcraft 5w-20, 2.65, 161
Amsoil 5w-20, 2.7, 165
Pennzoil Platinum 5w-30, 3.0, 167
Mobil 1 5w-30, 3.09, 169
Amsoil 5w-30, 3.2, 173
Castrol GTX 10w30, 3.2, ??
Redline 5w-20, 3.3, 145
Redline 5w-30, 3.8, 153
*Some manufacturers do not give the second digit accuracy, so order could change as the HTHS could have been as high as 2.64 (and deviously rounded off to 2.6!)
So my question is why would one use those expensive oils like Redline that have such high HTHS? You see lots of posts from Redline users that claim many magic things for the oil including better mileage and more HP. However, the science and specifications do not support that. In fact Redline 5w20 would be about the worst possible choice for mileage and HP. Even the viscosity index is poorest in the Redline. To somewhat answer my own question I understand that there MAY be some possible wear benefits in a higher HTHS oil, but if so, why not just use a cheaper conventional oil like Castrol GTX 10w30 that has the same HTHS?
Sorry for the long post,
