Originally Posted by burla
OP you can'r expect everyone to know every thing about your application, you need to tell us the spec oil. I do favor redline products in most cases, however the Amsoil atf is very good as well. There have been uoa's on Amsoil's atf that showed no shear after long usage, and you can expect that from Redline as well. For gears and transmsions their products are fairly equal. But we need to know the spec oil to see the correct version. Spec oil tells us viscosity range for proper operation of that vehicle. Use the correct fluid viscosty, either would be a great choice.
Search Redline ATF UOA's. I was surprised after 30K miles of useage examples either oxidized or sheared out of grade.
