Originally Posted By: gogozy
Originally Posted By: unDummy
I'd doubt that Z1 is GL4. It uses zinc instead of phosphorous as the seen additive. The dosage just doesn't look high enough. The Z1 price is too low and performance is too pathetic to think that there is anything exotic about it.
If you want to see what DPSF is, get a VOA.
Spec'ing ATF in a differential hints that its not stressed or loaded. My Toyota has Dexron ATF in the differential doesn't mean Dexron is GL-anything.
I think Redline D4 is relying on the base stock to provide a level of lubricity and film strength.
Which is better alone as a lubricant with no additives, POE or PAO? So, I won't agree with Amsoil's "EP" comment.
Boron was all but barely seen in ATF a decade ago. Now, even a lowly ATF has 50ppm with higher end ATFs showing 200ppm or more.
thanks. I contact Amsoil and seems like Amsoil is not GL-4 rated. they also don't think Z1 is GL-4 rated too. its interesting now because although there was no change on the rear differential unit on SH-AWD on RL, RDX, MDX, and Z1 was being spec since 2006. but now Z1 no longer being spec for it beginning mid year 2010, not even the new ATF-DW1. the dual pump fluid is called, and that's where i see a post on the element forum where GL5 was cited.
again, i appreciated for the response and i may switch to D4 for my rear differentials in future.
This logic is very, very wrong. Just because Redline says their ATF will meet the GL-4 requirements, do not interpret this to mean you can use it in ANY application requiring GL-4. Ask Redline if you think I'm trying to just make sales.
