Hello,
I have a 1987 Toyota Corolla CE80 with 1C 1.8 diesel engine and S50 manual transmission. European model, last months of E8 Corolla before E9 came. Workshop manual call for ATF in this particular application. It's an exception - all other manual transmissions in E8 call for a regular 75W90 GL-4 oil.
Obviously the biggest difference between 75W90 and ATF is viscosity - 75W90 is waaaay thicker.
So what would you use? ATF as in the workshop manual or maybe Redline MT-LV? It is much closer in viscosity to ATF than to 75W90. I have both Amsoil ATF and Redline MT-LV on my shelf and it's pretty hard to decide what to use.
And it's also worth mentioning that newer applications of S50 transmissions with C series diesel engines call for 75W90 or ATF, even though all S50 transmissions are rather the same.
