Originally Posted by edyvw
Originally Posted by typ901
U
It's available at Walmart online. I started using it years ago always purchased at W-M. It's C3 approved; which is for mid-saps oil, which is good for a DI engine.
https://www.acea.be/uploads/news_documents/ACEA_European_oil_sequences_2016_update_REV_2.pdf
ACEA does not have approval process. Oil manufacturers self-test oils against ACEA guidelines.
Valvoline 5W40 MST in old packaging had clearly stated wording that oil was approved against: MB 229.51, BMW LL04, VW 502.00/505.01, etc. New packaging does not have that language. On new packaging there is only language that oil is recommended for pretty much all important specifications, gas and diesel. But does not say it is approved.
I used old packaging in my BMW X5 35d as I got on sale at NAPA some 60 quarts for $2 per quart. However, really do not know what happened with approvals for that oil.
It's still listed as approved on bevo website as 229.51. As far as your statement concerning ACEA, not sure what value that adds since that's applicable to all oils not just my recommendation. So disregard all ACEA ratings as they are mfg tested? And Valvoline lists the oil on their website as approved and licensed for several specs you are stating the label does not include the word approved.
I ma not stating that ACEA C3 does not matter. I am saying that contrary to your statement, there is NO approval process.
Valvoline is "double dipping." It changed label saying that oil is recommended for BOTH BMW LL01 and LL04, and MB 229.5 and MB 229.51. Now, I think that Valvoline is trying to say customers that have BMW and MB gas engines: yes you can use this oil. So, per Valvoline it is approved for MB 229.51 and BMW LL04. However, it cannot be approved than for MB 229.5 and BMW LL01 as it is not High-SAPS oil. Valvoline might be approved (be aware that any change in chemical composition of oil requires re-approval) for CERTAIN specifications, but what they doing is market oil as applicable for engines requireing High-SAPS since the US moved to ULSG. That is not hones marketing (and Valvoline was always good in being transparent). They bet that people do not care for approvals.
I'm reading as stated from the Valvoline website not the bottle. More to the point, OP asked what can be used for his EA888 Gen3. This oil is approved for 502. He's not asking for a BMW or MB. It's approved for his application. That's why I made the recommendation. Your labeling argument is valid but is not germane to the OP's question. If you have an issue with the labeling contact Valvoline and ask them to clarify.
