Quote:
Can you explain "EAO filters?"
Sorry, I've always used Walmart's Supertech brand or Ac Delco (previously always had GM cars...first Honda)
http://www.amsoil.com/StoreFront/eao.aspx?zo=515729
Quote:
I picked a 2007 Honda Civic Si Sedan about a month ago. I'm just shy of 2000 miles, and still using the oil that came with the car. I live in Chicago, so we have all 4 seasons. This car will be daily driven throughout all 4 seasons.
Quote:
If you choose Amsoil, buy from a site sponsor. The XLF is a good value if you become a preferred customer. Currently it is $4.55 a quart. It gets cheaper if you buy a gallon. So how many quarts do you need? The reason I recommend Amsoil XLF is because you are going to be using the factory OLM. If you run the Amsoil XL you will be able to run it down to 15% with confidence.
Quote:
I very strongly recommend going to to Amsoil MTL now - my transmission started to get the 3rd gear notchiness, even with the "improved" Honda fluid, at 5-6k miles. MTL stopped that, and in time for the coming cold weather.
Quote:
First: When should I change the oil? I thought I read somewhere the proper first oil change was 3,750. Now all I can find is "when the Maintenance Minder reads 15%".
Welcome to the Si club! I've had a 2006 and just bought a 2007 here is what I did. Let the factory fill work, change the oil only if or when it reads add. If it's between the 2 dots don't change it no worries. This should be between 3,500 and 5,000 miles. If the stick reads add before 5,000 mark I used Chevron Supreme 5w-30 until 5,000 miles. Dump it and use synthetic. I would use AMSOIL ASL 5W-30 or Motul 5w-30 Eco-nergy for the type of driving you will be doing. I'm going to try the Motul 5w-30 300V OCI at my next 5,000 miles. But I have the AMSOIL ASL handy. My son loves the ASL in his 03 Acura RSX Type S. We have some AMSOIL dealers at this site who could fix ya up. I'll be posting some UOA's in the near future.
