- Joined
- Apr 12, 2025
- Messages
- 867
I was thinking about Mitivac but I want some recommendations. Recommend something that works well. I want to 4.8 quarts to my 2021 Sienna transmission
Neither your thread title nor your post are clear, so I'll ask ...I was thinking about Mitivac but I want some recommendations. Recommend something that works well. I want to 4.8 quarts to my 2021 Sienna transmission
I used that in my recent fluid exchange with 17 quarts , it pumps quarts fast and is cheap.something like this
Yep:Neither your thread title nor your post are clear, so I'll ask ...
What are you intending to do with the ATF? Are you pumping in, or out? Because the answer would depend upon the point of view.
You posted this: https://bobistheoilguy.com/forums/threads/4th-gen-toyota-sienna-atf-change.397186/#post-7290673
So there's no real need to pump it out.
Hence, I would presume you want to pump it in, but why would you be looking at a Mityvac? Those aren't used to pump into a system; they only evacuate lube.
If you are pumping the ATF in, I would recommend a common air-over-liquid garden sprayer, as RooflessVW noted. I've used them for putting ATF in my Lexus. Get a clean, new one and use it ONLY for ATF; don't use other chemicals in it.
FYI the MityVac pumps out as well. That's one reason I like it for oil change services; suck it our and pump it into a 5 quart container; easy peasy.Hence, I would presume you want to pump it in, but why would you be looking at a Mityvac? Those aren't used to pump into a system; they only evacuate lube.
I like my Mityvac but I've found the push-to-connect fittings can start leaking in use.
I think what's happening is the clear vinyl tubing collapses/relaxes where it's being pinched. Thus I think the solution would be to store it with all hoses broken down (easy). However this is a do-as-I-say-not-as-I-do situation because I've been too busy/lazy to take my own advice.
I wonder if @clinebarger has experienced leaks at the connectors?
How do you like it?Just grabbed this
Haven't used it yetHow do you like it?
This was great, I used it to pump 3.5 quarts MTF in no time. I think I paid 4-5 with coupon. The other style pumps that attached to the top of the bottle would have taken a thousand pumps. I swear, I probably pumped 15 times in total. There is some that gets lost in the lines I poured back in (3.5/4qt), but I cut the IN line shorter.something like this
I used it to fill the 2.2 qts of ATF into the 2011 Camry the other day. The nozzle for the fill hole nicely, but I held it anyways. Dunked the black tube into the 5 qt jug and let her rip. Easy peasy.
