Originally Posted By: DBMaster
I watched several videos on YouTube about draining/flushing/cleaning water heaters. (The term "hot water heater" is actually redundant.) All the processes seems a little different, especially regarding whether or not to shut of the water supply when draining and whether or not to drain just a little, or the entire tank.
FWIW, here is my process. I turn off the water supply valve. Mine is a ball valve that I installed to replace a gate valve that didn't do squat. Prior to that I used to turn off the water to the entire house. I open the relief valve to break vacuum. You could also accomplish that by opening the hot water tap nearest the heater in your house. I drain only enough out of the drain valve to clear any sediment. In my case, it was less than enough to fill a two gallon bucket.
I found that if I left the water supply on to "power flush" that it just stirred up the sediment and I got little to nothing out. Remember that because there is a dip tube, the cold water hits near the bottom of the tank. With the pressure off most of what settles at the bottom will drain out.
Good idea. I will do a first ever drain this weekend.
Thanks
Thanks
