Originally Posted By: Triple_Se7en
Originally Posted By: Thermo1223
Is it true, if you replace the anode rod like you are suppose to every so many years the heater my last well into it's 20's.
The rod lasts longer many times if you don;t overheat the tank.
If the water is always scalding hot, then you are abusing your water heater.
Ya but, most appliances require 140F to clean well enough that the bacteria that do live in the tank. Just install temper valves at the sinks.
