Originally Posted By: BigCahuna
At this time I would like to include you all in a prayer for my sons 5HP 22 in snow blower. Please allow this dumb thing to start, and the oil to remain liquid. And that the new gas line, and float bowl gasket seal against all forms of ethanol gas that might flow thru it. And that the impeller throw snow as far as possible, without stalling and causing the pull rope to break, again. I ask this so that I might remain at home and not have to travel long distances in the snow to work on this machine, again.Amen.,,,
The meek will inherit the earth. This blower sounds like the meekest of them all.
If the pull rope breaks, you can sometimes put an electric drill on the flywheel with appropriate adapters. For briggses I used to use a 7/8 12 point socket on 3/8" square to drill shank gizmo; the 12 points fit the squarish rope starter gizmo connection well. Then I could crank it up real fast, faster than the pull rope even. Cleared some old gunk out of "whatever" after a lengthy storage and it ran.
I tried that when a weedwacker had some unknown failure and no longer ran. I melted the drill. Though, it probably had something to do with the fact that it was a 6V cordless drill hooked up to a 12V car battery.
