I had a clean/recharge kit left from my true/flow foam air filter. My other car has a panel k&n it came clean fine with the true/flow kit but the oil doesn't have the red dye like k&n's do. My question is the oil the same minus the color or would the cotton k&n require different oil than the foam true/flow. The true/flows are naturally red foam where as the k&n's are pretty much white when clean.
