Rant:
This isn't about EV tires, but about how Hankook is characterizing EV tires as something extra special.
Ya' see, the YouTube algorithm decided I wanted to see videos about EV tires, so it recommended a bunch. It is clear Hankook gave some incentive to these YouTube content creators (probably a free set of tires) to promote their EV tires. The sales copy these content creators are reading from makes a number of claims that are misleading - and the content creators don't have the technical savvy to recognize this.
Chief among those is that because EV are heavier than ICE (Internal Combustion Engine) vehicles that the tire designed for EV's have a larger load carrying capacity. Sometimes this is explicit, sometimes it is implied. This is just not true. This just not how it works.
Ya' see, the load carrying capacity of a tire is set by tire standardizing organizations and is the same for a given size/load range and the vehicle manufacturers use those standards to specify what tire size is put on the vehicle - and therefore what is listed on the vehicle certification sticker.
Yes, there is a bit of difference depending on which standard is used, but that has more to do with the difference between metric units and English units (and rounding!)
The sales copy apparently also indicates that tires designed for ICE vehicle are just not suitable for EV's In the videos, this is also sometimes explicit and sometimes it is implied. Again, not true. Whatever advantage a tire designed for EV's has, also benefits an ICE vehicle - and vice versa.
Now I will admit that EV's benefit more than ICE's when it comes to rolling resistance (fuel economy) and noise, but regular tires generally last longer and that is usually not mentioned.
Bottomline: The tires don't care what the powerplant is. It could be steam and the benefits/disadvantages would be the same.
I go into more detail here: Barry's Tire Tech: EV Tires
/End Rant
/End Rant
