Ran the old champ this morning
Woke up 5AM to no power fired up the old champion genset filled up with fresh 87 got the fridge and a few circuits going to watch antenna tv found out arc fault breakers aren’t happy with the choppy generator power. Wife got a shower in firing up the on demand water heater so she was happy and power was restored in about 2 hrs. While I had the oil good and hot did an oil change refilled with Valvoline full synthetic 10W-30 from an AutoZone clearance 6 years old gave the Qt a really good shaking hope I don’t kill the 15 year old champion.
We recently took a trip to Puerto Rico and our Airbnb had a newish Champion tri-fuel ~7500 watt portable generator setup to run on gasoline. It was wired to a transfer switch. Worked like a champ for the pretty much daily power outages. Loud as heck though. It would run pretty much all the mini-splits, the fridge and what ever lights and outlets you needed.
very loud indeed
"arc fault circuit breakers....", another thing to Google; thanks. (different than a ground fault, I suppose?)
Yes these circuits are a total pain I get it they're critical in preventing fires but are very sensitive they will trip if you pinch your 5v phone charger just right in a night stand drawer.
I always found that “sparkies” know code - just like builders - and install GFCI in obvious places - but not where you often plug in hand held power tools …
there's even dual function breakers and devices that are Arc/GFCI.
