I have a Honda powered pressure washer with an Annovi Reverberi pump. I was using a product called General Pump Series 100 oil found here: http://www.generalpump.com/PDFs/TECHNICAL DATA/OilRecommend.pdf
It is a red color like ATF. It was all my local out door power shop sold so that is what I have been using. No problems so far and the machine has been running well for a couple years on the stuff(maybe 20 hours of total run time). Recently my local shop started selling Annovi Reverberi brand "crankcase oil". Would it be better to start using this oil instead of the General Pump oil? The instructions call for a 30wt oil and that is what the General Pump oil is and the A.R. oil says "multi viscosity". The exact product can be found here: http://www.fleetfarm.com/detail/ar-triplex-plunger-pump-crankcase-oil/0000000089856?utm_source=googleps&utm_medium=shopping%2Bsearch&utm_campaign=google%2Bproduct%20search&gslfah&gclid=CIqJguLD2bkCFUXhQgodV2QAkA
What do you guys recommend for this application. I want the best protection for the pump. Many thanks!
