Stihl RB800 pressure washer pump oil?
Northern va
what is the correct oem oil for this pump? The Stihl manual says ND30 or 15w40. Tag says SAE 30 so that’s what I’m leaning towards.
I looked on the Annovi Reverberi site and I believe the correct oil is their AR64516, but I don’t see anything referencing this pump exactly.
Here is a pic of the tag on the pump
My speculation here is that it needs oil used as hydraulic fluid. For that you can find a quart of ND30 (Non Degertent) oil at WalMart & of course 15w40. Do they allow for any detergent 15w40 b/c there are no non detergents of that grade on the shelf. I would say you'd want to reach out to Stihl & confirm beforehand.
Found the manual
https://www.stihlusa.com/WebContent...ls/STIHL-RB-800-Owners-Instruction-Manual.pdf
Stihl sells their own oil which is readily available, but I was wondering about using the OE oil. Probably doesn’t matter either way.
This other pic is what I believe to be the OE oil but I can’t confirm. I suppose I can call Annovi and see what they say on Monday
I called today and spoke to one of their tech guys. They said either would work fine. I went ahead and bought a bottle of their blue oil on Amazon. I asked about the Stihl oil and they said it was most likely rebottled ND30, but didn’t know who it was made by.
I’ll change it out after about 5 hrs or so of runtime along with the engine oil.
