- Joined
- Oct 28, 2025
- Messages
- 3
Have you located replacement valves, seals, unloader components, etc and successfully repaired any “off” brand, cheap axial pump(s) for a gasoline engine pressure washer?
The crankcase locked up on the horizontally-mounted Annovi Reverberi (AR) RMV 2.5G30 axial pump for my old pressure washer yesterday. The seal at the pump crankcase input blew out and the leaking oil is filled with metal.
Evaluating replacement pump options. Have not decided how much I am willing to spend; nor have I decided whether to purchase another axial. The Honda GC 190 for my pressure washer could probably power a small triplex pump. A CAT triplex is not a consideration, but a small Canpump triplex at $230 is. Some internet searching did not yield any information about availability of replacement internal parts for a $60 YAMATIC 3/4" Shaft Horizontal Pressure Washer Pump from Amazon. It is an option if I pursue a super “cheap” replacement. Am curious whether any forum members have had any success servicing this or similar cheap units and whether they considered repair worth the time and expense.
