My TDi will often use maybe a liter over a 10k OCI. But not always. Mine should not be drawing (much) of a vacuum at idle, but I'm told that long periods of idle can pull oil past the turbo seals. I would think heavy throttle would increase oil consumption, but probably not due to the turbo (extra heat, thinner oil, easier to get past rings?).
I'd just use a quality synthetic, that meets VW min specs, and check it once in a while. The turbo bearings do run hot, hence the need for high quality oil. But VW has been calling for long OCI's, upwards of what, 20k? in European applications.
