They run best on 5W-20 Pennzoil.
Contrary to popular belief automotive engines have not reduced minimum rod and main bearing clearances in many decades. Take a look at a shop manual on a 60s engine. Minimum clearances are no smaller now than they were in the 60s.quote:
After reading the thread about the police cars, a question popped into my mind:
What is it about Ford engines like the 4.6L V8 that can use 5W-20?
I understand the whole thing about tight bearing clearances requiring a thin oil, but don't all new engines have tight bearing clearances?
What would happen if a new GM or Toyota engine was ran with 5W-20 oil?
It's funny, because everytime someone tells me it's because of tighter tolerances (and then I correct them and say clearances) I always ask them to tell me what the clearances are in a modular motor.quote:
That is correct.quote:
Originally posted by G-Man II:
Tolerance would be nothing more than the allowable range of clearance, right?
I had the '70 version of that engine, L-48 I believe. It was still running strong with over 120K miles on it before I got rid of it. Burned very little oil, and you could still run it to 6K rpms without a wimper.quote:
Originally posted by Hirev:
Taking a look at a real GM repair manual for a 1969 300 HP 350 CI cast piston Chevy motor I got what is below.
That is obviously wrong.quote:
Main bearing clearance...#1 Thru #4 .0008 - .0002
I agree. But the bias seems to be to tell people that happen along here to ignore the factory recommendations and use thicker oil to "save their engine from wearing out", like there was some grand conspiracy.quote:
Not saying that a 5w 20 is bad or a 10w 40 is good what I'm saying is engines are not as picky about motor oil as some here seem to think they are.
That would be operator error.quote:
The oil slot is found in SBC small journal rods only and only on the rod cap on one side. It is why most all small journal rod bearings have a oil hole at the parting line. The oil slot goes thru the rod bolt hole area from the inside out and is directed at an angle to the bottom of the cam lobes as the crank spins around. Its was designed to squirt pressurized oil on the bottom of the cam lobes at low RPM. But also puts more oil on the cylinder wall.quote:
Also, HiRev, tell me about that parting line slot in older SBC connecting rods. Never did see any of those in the half a dozen SBCs I built over the years.
The MO 302s used in the 1967 AND 1968 Z/28 302 motors were small journal blocks and rods. Both of my 1968s Z/28s came with 2 bolt main, small journal 302s MOs. Only in the 69 DZ motor will you find large journals and 4 bolt mains. The 68 327s could be small journal or large journal depending on how early or late in 68 they where made. All the Camaro SS 350s from 67 on up were large journal.quote:
(In 1968, main and connecting rod journal sizes were increased on all small-block Chevrolet engines.)
