Question about dipstick tube extraction
Originally Posted By: HerrStig
Not hard to attach a smaller diameter hunk of tubing to that which the device came with.
+1 use nylon refrigerator ice maker supply line tubing you can buy at most hardware stores.
Originally Posted By: Benito
Just for my clarity, you attached to the dipstick tube rather than inserted the extractor tube down the dipstick tube?
Yes, using a special adapter that goes on top of the dipstick tube.
Pray tell good sir from hither one could procure this fantastical special adapter device.
Or dost thou pulleth mine leg?
http://www.fluidevacuators.com/products/hoses-adapters/mercedes-adapter-detail
However, some people reported that the rubber attachment that comes with your MityVac works just as well.
That's a great tip. Thanks.
Originally Posted By: dishdude
Allegedly I'm a member of the flash mob.
It's flesh mob.
Flesh is spelt with an "e".
Flash is spelt with an "a".
Obviously you're having spelling and comprehension problems.
I just have done it for the first time on my VW.
With this Pump: http://www.proxxon.com/en/micromot/25262.php?list
Problem: The extraction tube delivered with the Pump was a plastic hose with 6 mm outer size. >The Dipstick tube on the VW also has 6 mm inside, is curved and dont reach the bottom of the oil pan.
So, i just repalced the extraction tube with a piece of 5mm brass tube i bought in a R/C modell shop. It worked good. I just need to use a little bit of gentle force to press the brass tube down the dipstick tube. The brass tube bend perfetly to the shape of the Dipstick tube and followed the curved way.
I managed to get 3,5 Litres pumped out of the engine, wich, as i belive, is almost everything. If there are 0,2 Litres left in the engine i dont care. Every time i change the Oil on my bike 0,5 litres of old oil remains in the oil cooler. No Problem.
It's flesh mob.
A "Flash Mob" is a name for a group of people who assemble suddenly in a public place". What's a "flesh mob"?
It's flesh mob.
Someone's having comprehension problems and it's not dish dude.
I have no interest in correcting you though. If you'd like to know what a flash mob is try google.
And before taking a shot at a guy you might want to make sure your standing on terra firma so you don't look stupid
Irony at it's finest.
Btw, did you notice the wink at the end of my post to dishdude before you decided to attack me?
Yeah, sure, snarky.
Yeah, sure, snarky.
So you, like Clevy, seriously believe that I was correcting "flash mob" to "flesh mob"?
And you think the wink meant something else?
Seriously? That's what you believe?
