- Messages
- 2,271
- Location
- Cincinnati
I tried to use my MV 7201 last week to change the oil in the 2019 Outback.
I got it set up, the tubing into the dipstick tube and “bottomed out,” and checked that the metal valve on top of the unit was closed and the unit set to “extract.”
When I began the instructed ten pumps of the handle I noticed a slight hissing sound from the unit.
And I ultimately was only able to extract 1.5 of the 5 quarts in the oil pan.
I figured out that a) I needed a more narrow diameter tubing and, b) that I had pushed the tubing in too far and created a kink that prevented a full extraction flow. (See photo).
No worries. I used a smaller diameter piece of tubing and it went in easier in spite of the 90-degree turn in the dipstick tube.
I doubled checked to ensure it was at the bottom of the oil pan (the tubing was not going in any further), gave it ten pumps, and listened to the now expected slight hissing noise each time I depressed the handle.
And once again, I only managed 1.5 quarts on the extraction.
The tubing was not kinked in any way this time. And yes, that 1.5 quart draw the second time was after a 50 minute wait.
I am wondering if I have an issue (leak) with this new 7201? Or am I doing something wrong in my actual usage of this extractor?
