Originally Posted By: SumpChump
[size:14pt]
Originally Posted By: KGMtech
ZF has temperature settings for checking the level, drip rates for confirmation of level. However, no vacuum required.
Thanks for the comment.. It goes to show how odd this vacuum thing is that Toyota is doing.
The original procedure has no vacuum being used. LINK >>>>>
And the original process was long enough already.
The vacuum being applied is really bizarre. especially since the earths atmosphere is at 15psi and this applies, in the opposing direction, 3 psi of vacuum through a side fill port while you have the bottom drain plug open to atmosphere anyhow.
I got a laugh out of their equipment and essential tool list....to check the ATF! LOL
How is this hanging from a transmission pan BETTER than having an F*ing dipstick Toyota!!? LOL
Isn't 1 "atmosphere" 14.2psi?
And 3 bar = 1 "atmosphere?"
I did an estimate on on the atmospheric pressure and I think that 10-20Kpa is 3psi.
You can google this stuff, guys...
At sea level, 1 atmosphere = 14.7 psi = ~ 100kPa = 0 psig (the 'g' standing for gage, which measures pressure above atmospheric pressure.)
3 psi (not psig) is less than atmospheric, i.e., a vacuum. Every gage I work with is in either inches of mercury or water, including the duplex gages that measure pressure in psig on the other side of the scale.
With all of that said, it really sounds like you're getting upset over nothing. I am NOT a believer that lifetime fluids are really good for the lifetime of the vehicle, and that performance and protection will degrade over time, to include possible failure at higher mileage, depending on the service and other factors (e.g., manufacturing process, such as differing tolerances and entrance of contaminants.)
Based on the fact that I know many people who drive their dip-stick-equiped AT's to high mileage without even thinking about the oil, you may be over-reacting to this a little bit. I do test things for a living, so I'm biased when I say that this does not look very complicated to do.
Besides, who did you talk to about doing the job, the service writer? Service writers don't always know a lot about cars, and some know very little. I wonder if the tech's themselves would be able to figure it out.
Finally, why was the new method developed? Have people been having problems, failures as a result of the previous method?
*I removed links and pics from the quote...
