hey all! i am finally gonna change the atf in my 2015 rav 4 with the u760 transmission (similar to the u660)
i watched some youtube videos and feel like i have a decent plan.
here are the tools i gathered/gathering, lmk if i need anything else
1. meat thermometer to see the temp of the fluid when its flowing out for final level check
2. ir thermometer to aim at the sides to see when the fluid is hot enough for level check
3. 3 gallons of fluid to do the full flush
4. toyota oem transmission filter, gasket, filter o ring, maybe a few new magnets? i think i can reuse drain plug or am i wrong?
5. 3/8 id tubing to connect to the transmission cooler to dump out old fluid, i wanted a video and the guy said it was 3/8 id so i hope that is true - any way for me to check what that transmission cooler line size is?
6. battery fluid pump to pump the fluid into the fill hole, i hope my battery pump tube fits into the fill hole
7. level to make sure transmission pan is level for fluid check
8. obvs tools and jacks
9. buckets with fill levels so i can see how much has been dumped etc
anything else i need to make this easier or move smooth sailing?
hope i didnt forget anything
thx
thx
