yeah, there's science behind my decision - fewer vapors meaning less carbon buildup. You have yet to even form your point, so far debating yourselfI need before and after.
Point is my "solution" works great. Evidence: zero carbon issues in use. Other VW owners have carbon-cleaned their 1.8T GDI during my ownership period. Maybe you should try it.yeah, there's science behind my decision - fewer vapors meaning less carbon buildup. You have yet to even form your point, so far debating yourself
You’ve disassembled it and saw for yourself? That’d be a good evidence. Can you explain it to me, how exactly the additive makes it on top of the valves to clean them?Point is my "solution" works great. Evidence: zero carbon issues in use. Other VW owners have carbon-cleaned their 1.8T GDI during my ownership period. Maybe you should try it.
I have zero issues, why would I tear it apart - that is what I use the additives to prevent doing!You’ve disassembled it and saw for yourself? That’d be a good evidence. Can you explain it to me, how exactly the additive makes it on top of the valves to clean them?
You just presented the purest evidence you don't understand what you're talking about. I think we're doneI have zero issues, why would I tear it apart - that is what I use the additives to prevent doing!
Magic. Just like your Noack.
What are the advantages of a Euro oil compared to standard synthetics?Any Euro W30 oil.
You have numerous topics here, but pretty much they are more "stout" in every aspect. You will take 1% hit in MPG.What are the advantages of a Euro oil compared to standard synthetics?
It’s not really about the base stock but more about the stringent manufacturer approvals the oil may meet. The approvals demonstrate and document the oil’s performance.What are the advantages of a Euro oil compared to standard synthetics?
Haha! I think I’d have to side with most of your points surfstar made.I have zero issues, why would I tear it apart - that is what I use the additives to prevent doing!
OP - we need you to settle this, as we've sidetracked your thread too long. Flip a coin and let us know who "won" the internet today.
I tried to keep it specific to the oil that would best protect the engine over the long haul. My main concern is preventing carbon build up as this is the first DI engine I have owned.You have numerous topics here, but pretty much they are more "stout" in every aspect. You will take 1% hit in MPG.
Look for oil with MB229.52 approval. Mobil 1 ESP 5W30, Motul X-Clean+ 5W30.
Then, again, MB229.52.I tried to keep it specific to the oil that would best protect the engine over the long haul. My main concern is preventing carbon build up as this is the first DI engine I have owned.
I did change topics to adding an oil catch can, but it has gotten side tracked from others as well. I’m still somewhat new to this forum.
Well you have at least 2 adults here that just “feel” it. Reminds of a recent post where someone claimed they feel the difference in the throttle response when Redline is usedHow will the additives prevent carbon buildup on the backs of valves in a GDI motor?
The world wonders.
yeah it is minimal, like 0%Haha! I think I’d have to side with most of your points surfstar made.
Though SlavaB I see what you’re getting getting at. Not all engines, fuel systems and even DI setups are made the same. There are so many variables it makes it difficult to say for sure that something that helps one vehicle may not help a different one. But these additives are only going to help, even if it’s minimal.
Wemay is a living proof that the oil decision is not as important, probably ran everything but 0w16 in that PassatOP, as you're noticing in real time here, BITOG is all about splitting hairs. All you really need is an SP/GF-6 oil in the recommended viscosity. You can also choose Euro oils and/or different viscosity if you like as it's doubtful they'd cause any issue. Lots of good oils out there.
...and without trying to hijack the thread, I've got 6qts of 508 waiting for the next fill in the VWWemay is a living proof that the oil decision is not as important, probably ran everything but 0w16 in that Passat![]()
and what if I told you the same engine specs elsewhere in the world calls for 5w30 and other viscosities notwithstanding 0w20...simple CAFE garbage is at play here in US of AGood point on the oil filter!
I know higher viscosity oils than OE recommended have been discussed on quite frequently, but I’m not so keen on doing it on newer engines going to 0w20 or even 0w16. Mainly for the reason of the timing chains as PimTac had mentioned. Also on that issue is variable cam timing setups. The ECM is looking for and is programmed for specific pressures based on the oil viscosity. Changing oil viscosity can and will effect that system. By how much? Too many variables to account for, every manufacture and engine is different.
