I have been doing some renovation work at my rental house and tore up all the flooring to install Lumber Liquidator's premium hardwood vinyl. The nails from the carpet had to be pried out of the concrete foundation. A few of the heads broke off and I thought that I would use my Milwaukee M12 oscillating multi tool to cut off the remaining nail.
I started with a Milwaukee branded metal blade, which didn't do much. Then a Dremel blade, still nothing. Then I switched to a brand new HF metal blade which proceeded to grind all the teeth off and warp. All of this for a nail not much bigger than your average brad.
So I pose the question; who makes decent blades for multi tools that can actually cut something instead of self destructing? Anyone have luck with a certain brand?
PS: My Milwaukee Multi-Tool worked awesome for sanding down spackle on the walls! Way quicker and smoother than a sanding block!
