Originally Posted By: PurplDodge
I dobut that the oil in this motor has ever been changed (The filter is faded!), so it is a welcome addition! I would just like some suggestions on some good synthetics to put in this air-cooled beast!
That is a lot of hours with no oil change. I'm sure there had to be some used oil but given did the owner ever top the oil off? Seems like this is surreal.
Actually I've seen some who didn't care about changing oil or the filter itself...just top off. The engine had excessive heat and the oil was so dirty with so much junk in it the compression was not the same. Oil and filter were left on for over 6 years.
If your engine is still running I'd run a two quick run with conventional oil. Also how much life you got on this engine is questionable. I'd stick with a cheaper HDEO rather then using a more expensive synthetic oil and run till engine dies. Given the choice a 30wt would be more ideal than a 10w30 but you may need to step up to a 40 wt.
