OVERKILL
$100 Site Donor 2021
OG Ultra was the synthetic glass media ultra, superior to the later version in construction.What's an OG Ultra #2? An original ganster model Ultra of what brand?
Baldwin has a coil spring. No leaf spring. I say that based on Baldwin specs and filter disection videos I've seen. Every source I've ever seen is impressed with Baldwin's build quality.I don't think the Baldwin has a leaf spring, so maybe it's not a leaker. BR is the last source I'd choose a filter based on efficiency claim, maybe only if there was no other ISO 4548-12 efficiency info on the filter, like the Denso Toyota filters.
Most people don't know what "nominal efficiency" really is, so when they see just the micron size related to the nominal efficiency they don't have the whole story. A filter with nominal efficiency at 21u, which is 50% @ 21u, is going to be around 99% at 35u to 40u.The Baldwin filters my car can use are rated as 18 microns nominal, which I used to think was good because its better than Wix 21 microns. On the West Coast, and probably the West in general, Wix is king and sets the bar for most people here. I now think that's more due to clever marketing than performance.
Maybe consider the Fram Endurance ... the can on that seems thicker than most in its class. Or even a Fram Racing filter ... those have a really thick can, and I think they are around 95-97% @ 20u.My only concern with P1 is that I sometimes drive on gravel roads. Gravel can fly up and hit the oil filter can. A P1 can is thinner than Wix and much thinner than Baldwin. A Wix can is tough and unlikely to burst or be punctured by flying gravel. A Baldwin can is extremely tough and pretty much indestructable.
What does the OG mean? What brand is an OG Ultra?Just another OG Ultra .. so they both showed similar low particle counts. Same with the to MG (MicrGaurd) filers ... they both had similar particle counts between them.
Means the original wire-backed, 2-ply media version of the Ultra, which is no longer made in that configuration.What does the OG mean? What brand is an OG Ultra?
Sorry, meant MicroGreen, which is also no longer made.MG is Microguard? Is Microguard the Oreilly house brand filter?
The words Fram and racing made me LOL. It's hard to trust Fram because Fram is a swearword in my town. Also the Orange Can of Death expression comes to mind.Most people don't know what "nominal efficiency" really is, so when they see just the micron size related to the nominal efficiency they don't have the whole story. A filter with nominal efficiency at 21u, which is 50% @ 21u, is going to be around 99% at 35u to 40u.
Forget the name, look at the info and data, lol. You must have missed out on the OG Ultra being king here for many years, until First Brands bought Fram and started cutting corners. Some of that could have been pandemic driven, because Fram wasn't the only company cutting corners on their products after that event.The words Fram and racing made me LOL. It's hard to trust Fram because Fram is a swearword in my town. Also the Orange Can of Death expression comes to mind.
But I trust your judgement. So maybe it's time to let go of my mistrust of Fram.
I went several years without logging in at BITOG. So ya, I must have missed the OG Fram Ultra years.Forget the name, look at the info and data, lol. You must have missed out on the OG Ultra being king here for many years, until First Brands bought Fram and started cutting corners. Some of that could have been pandemic driven, because Fram wasn't the only company cutting corners on their products after that event.
No, they're all just PCs that have been posted on this site over the years.Are those all UOA PCs off your vehicles?
The problem with comparing the 4u or 6u counts from older and newer tests is that it seems that Blackstone changed the way they estimate these counts. They were typically at least 6 ISO codes lower than the counts they tend to report today.I think looking at the >6u particle counts might be a better way to compare, as the higher efficiency filters will stand out better at that level.
Baldwin gives specs for nominal efficiency (50%) and absolute efficiency (99%). The Baldwin filters that are 50% efficient at 18 microns are usually 99% at 40 micron,, which isn't very efficient.Baldwin's build quality appears to be top notch. Baldwin B35-S specs claims it filters 18 microns nominal. Wix 51036 claims it filters 21 microns nominal. What does that mean? Can we trust the manufacturers claimed specs to be truthful and accurate?
Wonder if a call or email to Blackstone can shed any light on that. Could be the reason for such a mis-match over the years - or leaky leaf springs are showing the effect, lol. The UOAs I took my data from were all done around the same time frame, so comparing the filters I show to each other should be pretty good. The end result was of course that higher ISO rated filters resulted in better particle count data.The problem with comparing the 4u or 6u counts from older and newer tests is that it seems that Blackstone changed the way they estimate these counts. They were typically at least 6 ISO codes lower than the counts they tend to report today.
For instance, a typical PC for a Mobil 1 filter was 16/15/13 back in 2010. A more recent Mobil 1 PC test was 24/22/14. I think Blackstone used to use a standard curve for estimating the smaller particle sizes instead of measuring them, since the 6u counts were always 2-3 ISO codes higher than the 14u counts.
Even the 14u counts from older tests seem to be slightly lower than what's typical for newer tests, but it's hard to say whether this is due to a change in Blackstone's test procedures
I did a particle count test on a BOSS PBL14476 at the 500 mile mark. I never got around to doing it again because of costs. The ONE filter is known to filter down to 20 microns. I little better than the BOSS. I do find my results adequate enough to stay with the filter.
It performed better than the Toyota filter which have been used on vehicles for 300k miles and more, and it doesn't leak past the bypass valve like many other "premium" filters.Wow, that's an amazingly crap result for a 'premium' filter.
I've used and cut my Purolator's for what 15 years never have a Tearolator.If you’re worried about media tears.
Do you have a UOA particle count with a Toyota filter on the same engine with only the same 500 mile OCI?It performed better than the Toyota filter which have been used on vehicles for 300k miles and more, and it doesn't leak past the bypass valve like many other "premium" filters.
Which model number? Not all models tore media.I've used and cut my Purolator's for what 15 years never have a Tearolator.
I agree. I don't think the Boss is crap. I think it's actually pretty good, especially in regard to capacity, flow, reliable valves, and tough can. Similar can be said for Wix and Baldwin that I've been using for decades.It performed better than the Toyota filter which have been used on vehicles for 300k miles and more, and it doesn't leak past the bypass valve like many other "premium" filters.
You mean the filters that show vastly lower particle counts, despite the hypothesized leak potential?It performed better than the Toyota filter which have been used on vehicles for 300k miles and more, and it doesn't leak past the bypass valve like many other "premium" filters.
I don’t know why they put number of particles as less than one. I guess some arithmetic cut them into pieces.I did a particle count test on a BOSS PBL14476 at the 500 mile mark. I never got around to doing it again because of costs. The ONE filter is known to filter down to 20 microns. I little better than the BOSS. I do find my results adequate enough to stay with the filter.
It was the old yellow can they call Pureone I used on my old Toyota I can't remember the specific number.Which model number? Not all models tore media.
