PureOne vs Toyota OEM?
NC, United States
For roughly the same money, I can get either a PureOne or a Toyota OEM for my 97 4 cyl Camry. Because of the dubious sludge history for this engine, the car gets a 5K OCI using Mobil 1 High Mileage. So which should I use or does it even matter?
I think the Toyota one has a Nitrile antidrain vs silicon in the Pureone. Not sure if that is enough to pick one over the other.
Over on Lexus forums, folks were quite unhappy with Thailand made Toyota filters compared to Japan made. Folks here have confirmed they have noticeably poorer filtration than the competition even though they are generally respected for good build quality.
So I would say that as long as flow restriction isn't a big issue with the Pure One compared to Toyota, then go with the Pure One.
I switched from the Toyota (Made in Thailand) Denso filters to the PureOne after seeing river_rat's bench testing and also this graph. It's a nicely made filter, but both indicated that they don't filter that great.
I don't know about that. I personally use 90915-yzzd1 made in thailand, DENSO. I am very happy with it.
Chevron Supreme & Toyota OEM Filter. I check the dip stick and oil is still look good at 3,000 miles. So OEM filter is good.
You realize how small 20 microns is right? You can't see that with the naked eye!
It's pretty much the standard particle size that people compare filters with. To many 20 micron particles can increase motor wear. Yeah, it's small ... but not small enough.
If you don't care about 20 micron particles, then just get a screen mesh filter.
Originally Posted By: moto94536
I don't care about the microns test. I use toyota oem oil filter with 100% confidence.
It's a free country ... use whatever makes ya happy!!
Wow, that's pretty compelling evidence. I can get the Pureone for a shade over $6; the dealer wants $4.89 for the OEM. The filtration test for the OEM is kind of scary.
Well I don't believe in the test results. You use whatever oil filter you like to use.
I will use Toyota OEM Filter only.
I'd go purolator and not look back.
toyota oem can be made by anybody at anytime. at least with a Purolator, you know what you're consistantly going to get.
I have Mobil 1 5w30 running upwards of 11k on my sister in laws sludger toyota, the motor's relatively clean and by 10k and about a half quart low. Pretty decent OCI.. then again, this car is mainly on the freeway so that might help.. but I'd like to think the Mobil 1 is doing its job.
Wasn't this thread about teddyboy seeking advice? Why make it about your own feelings?
I use(d) the OEM Toyota filter on my sister's '08 RAV4 while it was under warranty, not because I felt it was a superior filter, but because it's not my car and I didn't want there to be any possibility of a coverage issue should there be an oil-related problem with this vehicle. I always use, and recommend friends to use, OEM parts on vehicles under warranty...after that, I have my list of favourites...
teddyboy, I don't know why you are using 10w30??? 5w30 is ok to use.
I used the last of my 10W30 with the most recent oil change. A week or so ago, I bought 5W30 for the next change. Although it's hard to imagine that it's going to make a huge difference in my climate, learning that there is no longer a reason to use 10W30 is a lesson learned from the forum.
I'm generally the same but on this Toyota oil filter topic, I changed my mind a bit. The Lexus forums have had people who have visually compared the Japan vs Thailand filters and really not liked the Thailand filters. Tests have shown that a Motorcraft filter which has Purolator Premium media, filters much more effectively than the Toyota filter.
Toyota may and probably do know more about this than us, but I think Purolator also know how to make filters according to required specification, so I presume the flow of a Premium or Pure One is totally adequate for a Toyota engine. We know the quality is good. So why not get more filtering?
Most Purolator filters are pretty average in tests, but the PureOne model has been shown to be one of the top 5 (along with Mobil 1, amsoil, Bosch).
