PU or PYB 5W20
Originally Posted By: Silver_civic
Just got a little 98' Corolla, 4cyl, 4speed and has 200k on it from a friend that was moving. I am thinking of using either Pennzoil Conventional 5w20 but honestly thinking that if I dont drive it as much as my 03' civic, I could just go with a wix filter and Pennzoil Platinum 5w20. I have 2 jugs of SM PP that I got this past summer(last of the Pennzoil Platinum 5w20 SM I saw at wal mart). Would I be ok to use 5w20 in this car, or should I go with 5w30? Friend said it didnt leak or burn any oil also.
thanks in advance,
adam
adam
I would probably stick with the manufacturer's recommendation. I don't think Toyota issued a TSB (technical service bulletin) saying that 5W-20 is OK for that car.
For newer cars, the thinner the viscosity, slightly more is the wear. But since most people don't intend to keep their car for more than 300,000 miles or so, even the thinnest 0W-20 grade should be OK. Also, advanced ZDDP and moly in modern engine oil help protect against wear even when the oil film fails. For older cars, wear can be more abrupt; so, be careful with going to a too thin viscosity.
The main advantage of thinner viscosity is fuel economy. But there is not much difference between 5W-20 and 5w30 -- only about 1 - 2%.
Pennzoil Platinum or Ultra hardly has any advantage over Pennzoil conventional. They are slightly more shear-resistance (slightly less wear because they stay slightly thicker) and they are less volatile (slightly less oil top-offs). Stick with the yellow bottle.
If oil consumption becomes a problem, try switching to 5W-40 or 15w40. It will more than likely be the case for your car now or soon since it's 13-year-old, as the valve-stem oil seals are probably worn or about to be worn. By switching to a thicker viscosity, you won't have to add oil every 500 miles if or when that becomes the case.
Any conventional 5w30 will work great in that car for 6-7k runs.
Even though you've been told it doesn't use oil, still keep a close eye on the level.
Originally Posted By: Bill in Utah
I think its a belt. I think the 1ZZFE came out in 99?
Bill
Nope. 1998 was the first year for the 1ZZ-FE. It has a chain. The four speeds were less prone to burning oil than the three speeds for some reason. My 98 Corolla was in an accident over the summer. I don't have it any more but I had 203,000 miles on it at the time. Had 5W-20 in it as well. No issues whatsoever.
Hey guys, rainy day up here, and since the g.f. was having her wisdom teeth removed this morning, I took today off. I changed out the oil that was in there. I used the SM flavor Pennzoil Platinum in 5w20 I had. Popped the valve cover off and nice and clean there. Very well taken care of car also. The g.f. is doing good, as she is sleeping a lot, and on some heavy medications, but all in all doing good. When I had mine removed I was konked out for like 3 days.
Adam
p.s. thanks for the info and advice guys.
