I recently installed new tires (Pirelli Cinturato P7) on my Mazda3. I went from 215/45-18 to 225/45-18 (bigger selection in the 225 size, generally cheaper, and only throw the speedo off by 1 mph at 75 mph (this was also blessed by tirerack as being an acceptable alternate size). I'm aware that as a general rule, when tire volume increases tire pressure should decrease. The recommended pressure for the stock tires was 36psi. I'm assuming that the increase in size I went with is not too significant and only a slight decrease in PSI is called for. I know there are some complicated formulas to do this precisely, but I hope I can avoid that with some reasonably accurate seat of the pants adjustments. Does 34 or 35 psi seem OK?
