Protection of fence posts?
Roofing tar, then? Not sure I’ve seen non rubberized, tar-like undercoating.
Roofing tar would probably be a more cost-effective alternative to what I used. Permatex makes both asphalt based undercoating and rubberized undercoating under different part numbers as shown below. I used the 80072 version. Both are messy to use, so wear disposable nitrile gloves when spraying.
Thanks!!
We replaced a fence on our property maybe 12 or so years ago. Two main posts on the longest section rotted at the surface or just below. All the rest are fine, at least for now.
We changed them out. Put tamped gravel in the bottom to help with drainage. There wasn’t much in there from when the company installed them.
Is there anything that should be done for the posts to protect them more, before we fill the holes and tamp in all the soil?
Sika Epoxy fence post sealant. It looks like some ready to use others are a mix.
For full transparency, I ran out of the Permatex asphalt undercoating with two fence posts remaining, so I decided to pick up a can of the Rust-O-leum rubberized undercoating at WalMart instead of waiting two days to get the Permatex from Amazon. The Rust-O-leum undercoating was much less viscous than other brands of rubberized undercoatings that I had used in the past. It seemed to penetrate into the wood grain as well as the asphalt undercoating and has not peeled a year after installation. It is nearly half the price of the Permatex undercoating if that is a consideration.
I used Postmaster posts. https://postmasterfence.com/
For the larger gates, I used coated steel square tube (4"x4"). Over concrete, like the entrance to our breezeway I used custom variation with a plate at the base of the postmaster for bolting to the existing concrete. Steel is enclosed in cedar, not visible.
Eventually may corrode. I'll be gone.
Even re-coated ground contact posts don't last around here. The best luck I've had with wood are the round green farm fence posts.
I specifically sought out the tar-like non-rubberized coating for my fence posts. Everytime that I have used the rubberized undercoating on the undercarriage of a vehicle, it eventually peels away after several years. I suspect the same thing will occur on the 4" x 4" post and create a pocket to accumulate moisture. The non-rubberized coating stays tacky and doesn't ever peel away.
Like I said I have many posts that have been in the ground since 1999 and still have the undercoating on them...
First go round I rolled on roofing tar. This method is pretty crappy as you do need to mix the tar up (used a drill paddle) and it’s just miserable to work with painting in on. After that I moved to butyl flashing tape which was eeeaaasssy.
I would use butyl tape again, not the tar. I’m going to try that expanding foam to set the posts next time, rather than mixing up bags of concrete.
expanding foam is food for the little bugs, some call them silver fish, they are little bugs, that are silver........not sure what the actual name is.
