GM 2.4 timing chain gone amok! (and repair)
Iowa
Since we're all a bunch of of weirdos who appreciate a good bit automotive porn, I thought that I'd post up some pics of a job that I did a while ago. It was for a customer/buddy of mine who (still) has a 2006 Chevy HHR/2.4 He was in for a CEL, which was related the the VTC actuator. Pulling it out found lots of metal around the inlet screen. That coupled with a timing chain rattle meant bad news. He looked for some replacement HHR's and I looked around for engines locally and didn't find any, surprisingly and so we collectively decided to tear it apart and attempt repairing. Once in there, the damage was far worse than expected. Metal was EVERYWHERE and one of the cast in posts for the slack side guide was pounded so bad, that the 6mm bolt hole was severely ovaled. Hmmmmm... now what? He told me that if I could fix it, that he'd be willing to take the risk and that if it lasted a year or two he'd be happy.
Here is what I saw when I first tore into it
So now what to do? The new slot (ovaled bolt hole) was pretty severe and took up most of the diameter of the casting. A little measuring showed that most of it would be cleaned up by enlarging to 1/2", but what could I do with a 1/2" hole?? I thought about driving something in but decided against that as the sides were a bit on the thin side, but maybe I could tap it? I went the to drill and tap guide and found that 1/2" was perfect for M14x1.25. But no one had that bolt or all thread. Buuuuuut... BMW used it for their wheel bolts. So I tapped the hole and ordered one up from the parts store and set out to drill the hole to 1/2". Lucky for me there was JUST enough straight thread in the bottom of the hole to start a bolt. So I took an M6 and drilled a hole down through it and bought some 1/8" dowel material. I started the bolt, then filled the ovaled section in with epoxy for support. Once it was cured, enlarged the hole with an annular cutter, then finished it with a 1/2" drill bit.
A tap with a punch and the center bit came loose, just had to finish the hole out
Then I tapped the hole and made a threaded insert
And installed with some epoxy
Once I was (fairly) confident that everything would be okay, I went ahead and cleaned everything up (I actually pushed the car outside and hit the cylinder head with a pressure washer!) and installed the timing set and buttoned everything up
(and yes, right after I took the picture, I realized that I hadn't applied sealant around the oil pump port)
I filled with 15w40 and fired it up... Ran like a dream with no angry noises! I let it idle till warm and dropped the oil. LOADS of metal. Then several short drive cycles and more metal. I sent it out with him and told him to come back in 500 miles for another change - still more metal.. We keep the OCIs short and I use 15w40 in the summer and 5w30 in the winter. Anyway, it's been back on the road for approaching 2 years now and all is still good with it!!
Ish, he should change his oil once in a while. I am not a fan of those engines and they are completely intolerant to neglect.
I'm sure it's had the nasty start up rattle for thousands and thousands of miles.
No doubt he should be better to it, but autos aren't his area of concern 😂
He's fine with it dying, he'll find another and motor on with it.
Did you put a head gasket in it? That oil looked milky.
That's just an artifact of the bright light and metal in the oil.
I like seeing some interesting fixes and ingenuity.
I do too. I feel like we've become far too accustomed to just throwing stuff away and not actually using our brains for something other than a blunt instrument. We've definitely gotten spoiled with the amount of readily available cheap parts, but they aren't always available when needed (and the may not always exist in the future).
I do know my Japanese indie needed one for my car and nobody had it locally—he’s a shop so he has connections. Last stop was a machine shop and nope. He had to order from Amazon….
Just a brief update on this car - I did the work at 119,659 miles and since getting it back on the road the owner has taken it out of state several times as well as the usual around town travel - I just serviced it at 140,190 miles.. still humming right along. Honestly with all the metal in the oil (and still a noticeable amount as of this drain), I figured this thing would only make it 5k miles. It helped that I did lots of changes right away but dang!
