You don't need a cooler. That's another benefit of using a boutique, top shelf tri-synthetic like those listed. They not only tolerate high heat but thrive in it. Where oils like T6 and other common API rated oils are pretty much done at 240-250°F, those oils listed will handle 280-300+°F without a problem. The HPL Bad Ass oil doesn't even see peak friction coefficient until 305°F, much less thermal breakdown. Hot oil is happy oil, especially with E85.
