RIP HONDA
Well, it happened. Around Midnight tonight I decided to see if I could make the 20 mile trip from my house to my brothers. First 10 miles went pretty well. I just turned the stereo up and drove normally. Then it started getting louder and losing power. I drove another 5 miles to a gas station and grabbed something to enjoy while the metal parts cooled down. In the meantime, I wondered if bitog would be right. Would the car burst into flames and I somehow would be trapped inside? Would it lock up around a blind curve and a semi truck would find me soon after? Would it blow a hole in the oil pan near a protected fish reserve and end up poisoning the water?
Well, not exactly but I did have an encounter with a hill. The last 5 miles were hairy. The oil light was on for most of them. When I hit the 1 mile mark I was going uphill, floored, losing speed. Around 30 mph it blew a hole in the block. Felt like 2 cylinders were running. I pulled into a stone entrance to a farm field, smoke pouring out of everywhere, it shut off when I let off the gas.
I get a look at the hole, it's up pretty high. No meaningful oil on the street. I check to see if it will start, it does. Hmmm. I called my brother and had him drive over in my 04 Suburban which was in his driveway, incase I needed a push. At one point he did push me a bit but it wasn't necessary.
For the record, it still starts, it can barely pull away on it's own power, but once you get moving it can do 25-30. So maybe there will be a part II, final final ride.
