- Joined
- Dec 30, 2022
- Messages
- 60
As some of you know the oil filters on a 6.7 Cummins have instructions about sealing the gasket with fresh oil and then filling the oil filter up with fresh oil. This is on the mopar and fleet guard filters. Some on YouTube suggest to fill it around 75%
Anyway
As some of you know it’s a BIG PITA the first time because you’re screwing it on blind. After experience you really just know where the male threading is at.. the first time it took me an hour to find the male threading and screw it on.. now it takes me less than a minute
I don’t know how bad it is to have exposed oil possibly being contaminated by the surrounding dust on the engine.. especially the first few times when i was trying to screw it on blind..
I know you can put oil through the dirty oil holes so it can be filtered by the media BUT in the end you still have filtered oil exposed and depending on the surrounding environment of the engine it could get contaminated as tiny small amount of debris could fall into the filter..
Not sure if I should be more concerned or not. I change the oil in a garage so it’s somewhat of a controlled environment. I’ve done a few oil changes outside on other equipment but there was no wind or visible dust blowing around.
Anyway
