Originally Posted by BrocLuno
For a drag engine, it's all about how competitive you are? If you are Pro-Stock with a national ranking and a big sponsor, you know that ANY edge is important. So you will spend on machining, closing clearances, and running thinner oils. Your oils will be picked based on your data logger temp signals - sump is only one ... You are running "heads up", so first across the line wins. Now days you'll be running thin oils for the 5~8 HP it can deliver in reduced drag (1%). Your sponsor will be buying the engine parts
But, if you are a local runner who is doing Divisional Points racing, consistency is paramount. You have to run at the bottom of your index, all day, any day, any weather. That is a whole different ball game.
Redline would not be out of the question... But other oils would have to be considered too. Chevron Delo 15w30 SD (severe duty) would be on my list right next to Redline. Different formula, but I'd be testing to make sure it was within a consistent viscosity range over various track conditions? If so, it would be right in the top ten. Pennrite 10-10ths oil for the same reasons. JG Driven oils, Penn One, maybe John Deere +50 in a narrow multi, and some flavor of VR-1.
They'll all keep the parts happy. They'll all keep the cam and lifters happy (if the right parts were selected to start with ...). It'll all come down to bearing heat, ring seal, viscous drag, pumping losses, and the like.
One of the biggest jobs oil has to do is carry heat. These will all do that. So then we get to minutia like performance in the ring band at relatively high piston speeds (compared to street engines) and high levels of gas pressures attempting to blow by. Different oils will act differently here ... Some will seal better. But that is either found on the dyno, or with time slips over a season. Redline is known to be at least consistent in regard to ring sealing.
We need to know a lot more about the particular engine build? Total Seal/Perfect Circle rings, keystone rings, thin rings, standard rings, all iron rings, pressure backed rings, piston crown edge drilled to pressure back top ring, coated pistons (what coating), cylinder wall finish, piston material, etc.?
In your RPM range, I had plenty good luck running just old Hastings iron rings on pump gas. I absolutely
would not do that on an E-85 engine. But it also depends on your dynamic compression between 5~6 K ...
With iron rings, I got really good sealing with Delo 400 SD. No need for Redline. But prices for SD have gotten more crazy than Redline
Since posting this thread, I've picked up 5 quarts of JG Driven XP3 10w30 to try out next season. The car also has a TH350 with a 4000 rpm stall converter. It's a footbrake bracket car. The biggest consistency difference I've seen with this car was switching to E85. Beforehand, I was having to carefully adjust the dial-in as the temperature, air density, and humidity changed throughout the day. With E85, it much less effected by changes in the weather. The temperature can drop 10 degrees from one round to the next, and it still runs the same dial-in.
JG Driven XP3 (and all of their XP series oils) use short chained secondary ZDDP with 1700+ ppm of tri-nuclear moly / organomoly blend. I'm looking forward to trying it next year.
